Sharp AR-336 F9-00 Code
  • Copier Tech in Illinois
    • Jul 2025
    Our Company has a Sharp AR-336 in shop with the print kit installed. Once we set the system to recognize the Print Kit it came up with a F9-00 Code.
    We also need to know where the Meter Reading is Stored, Which Board and where that board is. We presumed it was on the main Logic board but no Luck there, we need reply's to this ASAP.
    Illinois Tech
    • 23008
    First try a simple reset P*C*, 14, Start, CA. Allow the MFP to complete initialization be connecting the network cable.
    If that doesn't work check that the SCSI cable is connected to the correct port, and that the port is enabled in simulation 24-44, A & B, set the port used to #1, the one not used to #0.
    If that doesn't help, you may have to replace the print card (if you can find one), (CPWBN1275FC52).
    The count and serial # are stored on the PCU EEPROM, so don't get tricky and try switching EEPROMS to lower the count. It will error out with a serial # mismatch.
      Thanks for the Help!!
      Thank you for the Information, My Senior Technician believes that the Product Serial Number that is stored on the customers computer they print off of is the solution to our print issues. As far as the F9-00 code this was resolved by setting that port you referenced to 1 from 0.
      So we hope to redeliver the machine to the client tomorrow and connect to their network and be able to print. (Fingers Crossed)
      As far as the Meter count he's not trying to change it, the board we had to use is off a machine with only 200k copies on it, our clients machine had 600K+ on it so we were trying to set that back up properly.
      I'm sure the client would love a machine with another 4 years of life in it vs. their machine that was almost on it's last leg.
      Thanks again for the post
      • Tech2002
        • Aug 2008
        • 334
        Sell them a Brand New State-Of-The-Art Sharp Digital Copier!!! That machine is about 100-yrs Old!
        • efe311
          • Oct 2008
          • 114
          eng. ebrahim fakhree
          about the f9-00 this error code is for the print kit & it solution is very easy try to change the cable of the print kit which is connect withe the machine fron port A to port B from the back of the machine if it's not work try to change the cable which connect from the machine to the print kit
          try sim 26-44
          u will found two bands A & B input 1
          about the meter u can change it from sim 83
          open the secret diagnostic mode ca-p-interrup - ca-p- interrup
          • blimpy1111
            RE:F9-00 I tried simulation 24-44
            From/Blimpy1111..yes I tried simulation 24-44..A & B..from here it only let
            me do simulation 24..I could NOT set the ports from 0 to 1..What am I
            doing wrong?? Please help!
              • 23008
              It's pretty simple. Up or down arrow to highlight the appropriate line, number keys to change the value, OK to lock it in.
              A service manual might help out in this situation. =^..^=
              • JustManuals
                • Jan 2006
                • 9838
                This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment
                from The Internet's largest collection of manuals
                Paul@justmanuals.com
