AR-407 with F2-37
  • axyun
    • Aug 2007
    • 1323
    AR-407 with F2-37
    Cleaned drum,especially mark area, cleaned drum mark sensor and main charger but still f2-37. Drum looks a little fatigued.
    I already left customer's office and realize I didn't do a 44-02 simulation after cleaning. I am going back with drum and blade. Should that take care of problem? Any advice is appreciated very much. Frank/ActionPhotocopy
    • 23009
    I would try 44-02 first, before doing anything else. That resets the drum mark sensor, and your readings may be adequate. If that fails, then yes, replace the drum. Be sure to run 44-02 again when the drum is installed.
    • axyun
      • Aug 2007
      • 1323
      Thanks Blackcat.
      • vincent64
        • 382
        Take a look at the status report on that machine, TC 22-6, print it out, look at the drum counter number, if it's over 500 K.
        Think about replacing the drum, as I recall, that counter counts drum revoulitions on the machine, and if its 500k + its near its life, a OEM drum will go about 2 PM cycles.
        I liked the cougars, you could push the supplies if you had to.
        • axyun
          • Aug 2007
          • 1323
          Thank you Vincent. Frank
