Error code E7-02
  • Peter Sim
    • Sep 2008
    • 445
    Error code E7-02
    Hai all, i need help.
    My sharp copier AR-M450 show e7-02.I change the laser motor, still show e7-02 code.
    I do the sim61-1,it show..... NG
    Should i need to do adjustment or clear error code before i fix the laser motor ?
  • xeroxsharp
    • Nov 2008
    • 270
    E7 02 Content Laser trouble
    Detail BD signal from LSU is kept OFF, or ON.
    Cause The connector of LSU or the harness in LSU
    is disconnected or broken.
    The polygon motor does not rotate normally.
    The laser home position sensor in LSU is
    shifted.
    The proper voltage is not supplied to the
    power line for laser.
    Laser emitting diode trouble
    PCU PWB trouble
    Controller PWB trouble
    Check and
    remedy
    Check for disconnection of the LSU
    connector.
    Use DIAG (SIM 61-1) to check LSU
    operation.
    Check that the polygon motor rotates
    normally or not.
    Check light emission of laser emitting diode.
    Replace the LSU unit.
    Replace the PCU PWB.
    Replace the Controller PWB.
    HOPE IT WILL HELP!
    • lky1978
      • Mar 2009
      • 483
      change laser unit.
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1885
        If the polygon motor wasn't working you would get an L6-10. The E7-02 means the beam detect sensor never received a beam from the laser. As the previous poster stated you'll need a new laser unit.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • Peter Sim
          • Sep 2008
          • 445
          Thanks xeroxsharp,ikyl1978,tmaged for your reply.Meaning that i need to change the whole laser unit but not the polygon motor only?
          • tmaged
            • Oct 2008
            • 1885
            Correct !
            Hope that helps !
            -Tony
            www.dtios.com
              • 23008
              Like Tony says,
              L6-10 = mirror motor
              L7-02 = laser diode
              either way order the laser unit.
              • Peter Sim
                • Sep 2008
                • 445
                Like Tony says,
                L7-02 = laser diode
                Thank you blackcat4866.
