I'm getting this on a few machines. Have tried everything on SharpNet & IDNC Service. All tires & one-ways in tray 1, new PPD sensor, new one ways in pass unit (per tech tip) & new clutch pack on back. My next step is to flash it. Thanks for any input.
AR-M550N Jam code PPD_NT1
This is what I've got:
Misfeeds jam code (APPD_1, PPD_NT1) from tray #1 only. The PF return spring may be damaged or missing. Replace the PF arm return spring (MSPRT3254FCZZ).
Here's a really common one: Misfeeds (jam code PFD2_ST1, PPD_NT1) from tray #1. The separation drive coupler jumps, allowing multiple pages to jam at the bite of the rollers. Install a coil spring (14mm coil x 20mm length) between the separation tire side of the coupler and the E-clip and the E-clip to keep consistent engagement.
Misfeeds (jam code PPD_NT1) only from tray #1. One copy OK. Second copy jams 60mm out of tray #1. Paper dust contaminates sensor PSD2. Clean sensor PSD2 with a tiny brush. Remove inner left door. Sensor PSD2 is located at the lowest part of the guide.
I hope this helps you. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
OMD-227
Replace PPD1 sensor with modified part number QSW-Z0538FCZZ. When this sensor is old, it is somtimes slow in responding, causing jam codes. This part number fixes this issue.Comment
Thanks as always for the help.Comment
OMD-227
I hope this helps you. =^..^=Comment
I'll have to take a glance at my manual. I have it documented in the database, but don't remember the occasion. I'll post about it tonight. =^..^=If you'd like a serious answer to your request:
Found it. PFD2 has the same sensor number as the PPD sensor. I'll try that one.
Thanks,Comment
Just thought I'd let you know what I found. We brought a machine in that came off a lease. It had a bunch of the PPD_NT1 jams on it. We had a parts machine to trouble shoot with. It ended up being the black transport guide in the left door that the transport belt mounts on. I can't see anything other than wear in the plastic from the pages, but it took care of it on both machines. Maybe it'll help someone else out.Comment
Thanks Tony!If you'd like a serious answer to your request:
