M-550U---Ser. Code L4-06
  • wulffservice
    Service Team ******
    • Jul 2009
    • 29
    As a wholesaler of used copiers we get a lot of different makes and models of equipment. We have no access to manuals other the Itravia Books. We do not have the latest version for the above machine and would appreciate any information on this code and possible resolutions. Thanks in advance for any help!
    • 23009
    You'll be delighted to know that we have a local manual provider right here. Go to The Internet's largest collection of manuals
    The L4-06 is a transfer belt separation motor error. To diagnose it you'll need to do a simulation 14 reset. Most likely you've got a seized bearing in the transfer belt unit, or a ripped transfer belt. =^..^=
    • wulffservice
      Service Team ******
      • Jul 2009
      • 29
      Thank you BlackCat
      I appreciate the help.....I'll take a look at the points you brought up. And thanks also for the website on manuals.....for what we do, this just may come in handy! When I get a break, I'll head on over and have a look-see.
      • Bsam
        Sim mode
        You can check that tranfer belt using simulation 6-1. To get in service mode press #, *, C, *. The maintenance kit for the transfer belt is AR-620 KB. I hope this helps.
        • Old Timer
          As a get you out of trouble the cassette lift motors are the same as the transfer belt lift motor, also the motors have been modified for a longer life new/modified part number ends FC358.
