Sharp arc-150
  • Copier Systems
    • Aug 2025
    Sharp arc-150
    Working on a sharp arc-150-with code uo-80 had problem before removed and re-set connectors problem went away.anybody know the fix for thar codeThanks Andy H.
  • ezduzit
    Did you clean the connector to the transfer belt unit in the back of the copier? If so make sure you didnt bend in any of the copper connectors from the male side of the connector.
