Sharp AR-M455 code E6-11
  • J_Lee
    • Oct 2008
    • 111
    I have a customer with E6-11 error code and when I get there the machine won't allow you to do 2 sided copies. I reset the error in simulation and it works fine for a while then goes back. I have tried swapping the reference plate out as the manual says to do and I have swapped the CIS unit also with no luck. Any suggestions?
    Thanks,
    J
    • 23010
    It just gets more expensive from here on.
    I'd try reseating all the SPF connectors, then replacing the main SPF harness next, then replacing the scanner PWB. =^..^=
    • Dark Helmet
      • May 2009
      • 867
      Take a look in the back of the DF and see if any staples have fallen down there. The size detector on that model opens a little gap that crap can fall through right ontop of the scanner board.
      Also check the connector that goes to the MFP for bent pins.
      My memory is a little foggy on this one but there is a board that sits ontop of the CIS and if it blows up i think it gave the E6-11. In training there was a little accident and that board got mixed up between a 355 & 350. Poof!
