Sharp mx2700 error code dk
  • gitana1983
    • Mar 2009
    • 141
    Hi everybody,
    does anybody knows what this error means? We still don't have the service manual but we think is a maintenance related problem.
    If anybody can help me now it would be really appreciated.
  • DavePo
    • 305
    It is Black Drum code. Should also be black developer and primary transfer belt are at 100k.
    • gitana1983
      • Mar 2009
      • 141
      Is there any way to reset it?
      • DavePo
        • 305
        Yes Use TC 24-07
          • 23009
          There is some logic to it:
          Drum Cyan
          Drum Magenta
          D
          rum Yellow
          Drum blacK
          • OMD-227
            Even if you reset it, you will still need the drum unit or drum/mc kit replaced very soon. They dont last much longer than specified, before you get totally crap C/Q (lines etc etc). Eventually the drum edges wear away so much, they start pulling dev out of the dev tank.
            You can usually get away with not replacing the K dev. If you reset the K dev at the same time as replacing the K drum unit, the machine adjusts itself and works really well. Maybe a dev stir here or there, but the dev usually lasts 200-300K.
            Also, the primary belt unit lasts alot longer than the 100K spec. We always get 200K out of them before replacement or refurb.
            All up, do the drum, reset as above. Make sure Firmware is up-to-date. Alot of new fixes recently.
