Ar337 h3-01 error
  • efe311
    • Oct 2008
    • 114
    Ar337 h3-01 error
    I HAVE SHARP AR337 That take me error H3-01 & only right heater lamp is on & the left lamp didnot work when i make sim5-2 to test the heater lamp i change the heater unit & make sim14 & change the AC-power supply but the H3-01 is stell
    • 22996
    Have you replaced the sub-thermistor? Have you checked the continuity of the thermostat? It may be open. If the thermostat is closed check the modular connector on the back of the fuser. They've been known to arc. If that's the case it will be obvious, from the black soot and melting plastic connector.
    • efe311
      • Oct 2008
      • 114
      i change the heater unit from working machine
