sharp ARM450
  • adel_nagieb2000@yahoo.com
    • Jun 2009
    • 14
    sharp ARM450
    someone help me
    sharp ARM450 work very good without use feeder
    when use feeder and after three or two paper . the machine is power off
    i must turn off the machine and power on
    to work and rebeet that error
    can someone help me
    thanks
  • conny
    has the machine printer installed?
    if so try and change to antoher printer controller
      • 22990
      If you were getting an error or jam code that might help us to diagnose this problem. From the information you've provided, I can only speculate. =^..^=
        • Jun 2009
        • 14
        The machine printer installed and working without problem
        • lky1978
          • Mar 2009
          • 482
          Originally posted by adel_nagieb2000@yahoo.com
          someone help me
          can someone help me
          thanks
          maybe the feeder harness broken,difficult to change also.
          • fireater
            Repair God? not quite
            • Apr 2006
            • 253
            um redescribe this to me. the machine shuts off? while using the feeder? or does it go into an error? does it work ok from the glass? or it goes into an error? if it shuts off i would start by looking at the harness to the feeder/ scanner. if its an error post the error code so we can help you.
            I fix copiers ...Well Sorta
