Sharp AR-287 E7-07 error
    • 23009
    #16
    It sounds like you got a bad HDD. You can try to format it, or try another one. There is a remote possibility that you're experiencing an ICU board problem, but the HDD is still the most likely. Have you checked the DC power to run the hard drive? Maybe you've got a bad power supply...
    • J_Lee
      • Oct 2008
      • 111
      #17
      Optics?
      Could it be in the optics because it only does it when copying. When you print internally it doesn't do it? Also, it doesn't throw the error code anymore... only in the beggining???
        • 23009
        #18
        You may get a temporary reprieve, but eventually you'll end up changing a hard drive. Those codes don't just 'heal themselves'. No it's not optical.
        • J_Lee
          • Oct 2008
          • 111
          #19
          FIXED!
          Turned out to be the scanner PWB. After months sittin in the shop.
