Sharp AR-287 E7-07 error
  • J_Lee
    • 111
    I have searched many Sharp manuals and all of the manuals DO NOT have the sub code 07 in them. I dont have a 287 manual and thats why I was looking at other Sharps. I know it has something to do with the optical system but dont want to start tearing into a machine this old when I dont know too much about it. What is the error and how do you enter simulation? Thanks,
    J
  • ZOOTECH
    Senior member of CRS
    • 3375
    Well, the original manual doesn't have an E7-07 code. It might be a false code caused by arcing in the main charge; check that and the ground strap behind the suction belt tray. Some customers have forced the lift handle in the wrong direction which can break that ground wire.
      • 23010
      The Cougar manual doesn't show this code, but from the Whale manual: "ICU gate array trouble". Just because the code isn't listed in the Cougar manual doesn't mean that it doesn't exist.
      I'd try the ICU PWB.
      • J_Lee
        • 111
        Customer made a mistake the error code was E7-03. Sorry guys. I went over and cleaned optics and lubricated rails and a coupke other minor things and no call back so far. I dont even have this manual so Im not positive if it has anything to do with optical section. But I searched the internet and some of the E7's were optical so we will see what happens. Thanks
          • 23010
          Uh-oh. HDD trouble. Hard drive failures on cougars are very common.
          • J_Lee
            • 111
            So what does that mean? The customers only use it as a copier. What exactly is a hard drive error and how does it affect just copying?
              • 23010
              As an example, when your doing a sort copy job, the HDD holds the whole copy job, then providing the page data as needed, i.e.: pg 2, 1, 4, 3, 6, 5, 8, 7, etc., then on to the next set 2, 1, 4, 3, etc.
              • J_Lee
                • 111
                OK.... gotcha. Well I reset the error in simulation and cleaned the optics which I thought had something to do with it but as you said, it doesn't. Customer hasn't called back but time will tell. Thank You.
                • J_Lee
                  • 111
                  OK Came Back
                  Copies are streaking now as in not going into memory correctly. Not a copy quality issue optics are clean class is clean. Probably HDD problem like you said BlackCat. Let me ask you a question... Would the hard drive from a 335 fit in a 287? I have a 335 parts machine in the shop that hasnt been stripped to pieces.
                    • 23010
                    If the drive is the same size you can just drop it in. No need to format. It probably isn't the same size. The AR-335 is an earlier build than the AR-287. They aren't very similar as electronics goes.
                    Occasionally I've gotten lucky with a similarly close size drive. You won't do any harm. It'll work or it won't.
                    Another option is to take the manufacturer information off the original hard drive, and Google search out a replacement. I've had good luck with that.
                    • J_Lee
                      • 111
                      Where?
                      Where is the hard drive? I opened up the back of the machine and looked all around. I think Im looking for something that looks like the hard drive in the formatter of the HP Laserjet 9050. Does it look like this. I know Im going to feel dumb after you tell me.
                      • ZOOTECH
                        • 3375
                        The HDD is located in the scanner section to the right of the lens/CCD under a cover.
                        • J_Lee
                          • 111
                          Replaced hard drive... Came Back
                          Got part number from the seagate hard drive had one ordered popped it in and made some packets for the customer worked great... The next day they called in doing the same thing. Had to take them a loaner brought their machine in. Could it be the laser or could I have possibly gotten a bad hard drive again. It was refurbished by the way....???? H E L P. Also I am doing an HDD R/W test and its taking a long time... Should it take so long?
                          • Hemlock
                            • 432
                            There's a tranny joke in there somewhere.
                            โ€œAnti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'โ€ (Isaac Asimov)
                            • J_Lee
                              • 111
                              lol
