sharp ar507
  • cargocrusher
    • Jul 2025
    sharp ar507
    Getting an error, toner sensor and toner add, toner replenish was told it was the sponge roller in toner add, do not have part number. Also in exit section red rollers are deteoriated, any parts manual for me to reference would be nice
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment
    from The Internet's largest collection of manuals
    Paul@justmanuals.com
    • cargocrusher
      sharp ar507
      only saw the field service manual, looking for parts manual..
      • JustManuals
        • Jan 2006
        • 9838
        http://www.justmanuals.com/sharp-digital-copier-287337407507-parts-service-p-32726.html
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1885
          If it's an F2-00, too much toner got into the DV. You'll have to replace the toner roller & developer.
          IMO not worth it. The Sharp AR-501/505/507 were one of Sharps worst in recent history. As of yesterday, we only have 1 more left to get out of the field.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
          • Nachoman4life
            • Oct 2007
            • 212
            you dont have to replace the DV, after replacing the roller (and side seals) and re adding the toner, run a 25-1 with the charge unit out,( it will c1-00 but hit exec again and it will run) it will pull excess toner to the drum until the DV reference is back to the 100-130 range (you will have to stop the sim it wont do it for you), if you do it this way you will have to reclean the trans/sep unit, maybe the pre fuser transport, I'd also pull the drum afterward and reclean the cleaner unit, and mylars below the dv unit, maybe also a quick vac of the waste toner pipe. Thats the way I do it.
            Where the heck is my spring hook?
            • tmaged
              • Oct 2008
              • 1885
              Originally posted by Nachoman4life
              you dont have to replace the DV, after replacing the roller (and side seals) and re adding the toner, run a 25-2 with the charge unit out,( it will c1-00 but hit exec again and it will run) it will pull excess toner to the drum until the DV reference is back to the 100-130 range (you will have to stop the sim it wont do it for you), if you do it this way you will have to reclean the trans/sep unit, maybe the pre fuser transport, I'd also pull the drum afterward and reclean the cleaner unit, and mylars below the dv unit, maybe also a quick vac of the waste toner pipe. Thats the way I do it.
              Wouldn't you want 25-1 ? 25-2 will set the DV refernece with all that toner in the DV.
              Hope that helps !
              -Tony
              www.dtios.com
              • Nachoman4life
                • Oct 2007
                • 212
                good catch my fault
                  • 23008
                  Try searching "Sharp foam roller". You'll find a half dozen posts on this subject.
