ARM450 - How do you change the drum?
  • sgpm
    • Sep 2008
    • 16
    I was able to remove the drum assembly from the machine but could not figure out how to get the drum out. The spring that holds it doesn't seem to compress enough to release it so I'm guessing there's some other way?
    Thank you much for your help,
    Greg
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1888
    The 3 gold screws on the front of the drum unit will pull the post out of the drum. You really should pick up a service manual. It has all that stuff in it.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • sgpm
      • Sep 2008
      • 16
      Tony,
      Thank you very much, that did it. I do have the service manual but for some reason I could not find the information there.
      Thanks again,
      Greg
      • Dark Helmet
        • May 2009
        • 856
        Don't forget to reset 24-11 when you change your drum. The drum rotation counter is reset there and that is what Process control uses.
        I don't think there is any mention in the book to execute this either
        • sgpm
          • Sep 2008
          • 16
          Did that already Lawrence, but thanks for the reminder.
