arm-450 print distortion
  • DINGO
    • 661
    Hy.
    Y have a problem with one arm-450n, that y get prints and copy with beguin distortion?
    Can somebody help me?
    If was only in copy, y can try adjust in spf, but my problem was the print, there possible adjust to?
    thanks a lot in adavance.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1880
    Can you scan one and post it here?
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • DINGO
      • 661
      re
      Ok
      Y apreciate any help.
      here go the original and the print test. ( was print not copy)
      thanks
      • tmaged
        • Oct 2008
        • 1880
        Dingo, you can do a self print with the grid in 64-1 Pattern 71. If it's out of tray 1 only, either replace the cassette or check the tabs on the bottom of the black guide inside the door. If it does it out of all cassettes, remove the paper dust cleaner, 2 screws & unplug the resist unit. Check if it's tight. Clean & lube it.
        Hope that helps !
        -Tony
        www.dtios.com
        • DINGO
          • 661
          • lky1978
            • Mar 2009
            • 483
            dingo try to print the custom setting list , the straight line got distortion or not?if got u need to adjust lsu position(can learn from service manual),if nope, u lucky,u only need to adjust the feeder that much easy than lsu
