Had a complaint that the Doc Feed was miss-feeding. Checked and Cleaned All Feed - Rubber was good. Everything seemed fine. Got another call with same issue. Changed Feed & Sep Rollers. Cleaned All Rollers Top-Side and and Below. Everything seemed fine.
Got another call with the same issue. Seems that Doc Feed feeds 4 or 5 sheets of paper then miss-feeds. I have had Sensor Signals - SPPD1 & 2, SPPD4 & 5. I have not done a Load Test yet.
Am I looking a changing a Torque Limiter or Transport Motor Clutch? Or is there something esle I should be looking at?
Input and suggestions appreciated.
