AR 207 scan
  • lakeman78701
    • May 2008
    • 44
    AR 207 scan
    The AR207 I have has network print with ethernet cord jack. Can I scan with it also by installing the scan software, or do I need another board and what is it? THanks
  • ZOOTECH
    Senior member of CRS
    • 3375
    If it is just an AR207, it does not have a scan option. If it is an ARM207, scan is built in.
    (I think)
      • 22999
      Zootech is correct. The AR-207 does not offer scanning. The AR-M207 can scan in black & white as built, and in color with the AR-NB2N & EB7. =^..^=
      • Comingapart
        • Jun 2008
        • 44
        I think you might be mistaken. The AR-M207 can color scan out of the box through USB.
        It will not color scan over network regardless of installed options.
          • 22999
          I've never installed those options, but that information came directly out of the configuration sheets provided by Sharp. If it's incorrect, I'd like to know. Wazza?
          • swagreis
            • Jun 2008
            • 92
            i think from your words Lakemen that u have ARM-207 with network box so u can make network scanning with using sharpdesk version for scanning network with specified number of users.
            • OMD-227
              Local Scanning:
              ARM160 through to ARM207 has USB Scanning out of the box.
              ARM160 & 205 has USB1.1 default. AREB7 required for USB2.0 scanning.
              ARM162 & 207 has both USB1.1 & USB2.0 default.
              All scanning is done through Sharpdesk, button manager or TWAIN.
              Network Scanning:
              ARM160 & 205 require ARNB2N kit. Full resolution range is available with additional memory installed (75-600dpi).
              All scanning done through Sharpdesk, FTP or email.
              ARM162 & 207 require ARNB3 kit. Full resolution range is available with additional memory installed (75-600dpi).
              All scanning done through Sharpdesk, FTP, email or 200 destination maximum.
              Above listed ARNB2N & ARNB3 kits allow for network printing. USB printing only otherwise.
              The info I have on all the different configurations required for each model COLOR scanning is way too much to type out here. If you want it, give me your email address.
              • adel_nagieb2000@yahoo.com
                • Jun 2009
                • 14
                i thank you must change the printer board if the machine ar207 not arm207
