237/277/257/317 Top tray tires.
  • tmaged
    Owner/Service Manager
    • 1885
    How the hell do you guys change them ?? If they made the cover just clip in, it wouldn't be too bad. It's a PITA to get a right angle driver. We usually pull off the ADF, pull out the supplies, remove any extra cassettes & do it through the bottom. Is there a better way ? We have a TON of these out.
    Thanks,
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
  • glewisme
    • Nov 2009
    • 240
    Feed Tires
    Hey,
    Just remove the DV unit and the Process unit (some prefer to remove the fuser too),use a ratcheting right angle (or stubby Phillips) and remove the gray cover (has 3 pressure rollers on it)just below the fuser. Then just swing up the PF assy and remove them and replace them.
    • bilyahn
      • Dec 2006
      • 1470
      Originally posted by glewisme
      Hey,
      I like the JUST start here! HAHAHAHAHAHa
      • vincent64
        • 382
        feed rollers
        Yepp, pull the supplies, you can leave the fuser in, or pull it, but to change the sep pad for the top tray you have to pull the MFT out, to get to the plate that hides the sep pad unit there, the other way is to pull the LSU, and go in that way.
        I have a stubby that just fits, till I back the screw out
        I have found a knurrled bit spinner, least thats the name I am giving it, got it from Sears, one side fits a 1/4 inch ratchet, its square, the other side fits std. driver bits, and has a magnet insert in there also.
        Get a 1.5" long #2 phillips bit, and it will just reach into the hole where the screws are, and good luck.
          • 23008
          I've got the same one, Vince.
          glewisme and Vincent are correct. That way is easy as cake (or is it pie?). Just be careful not to deform the mylar on the edge of that cover. If you get streaks in the feed direction, the pre-transfer mylar may have peeled up and is making contact with the drum. I've done this to myself before. =^..^=
          • mtech
            • Mar 2007
            • 307
            Remove the dv and drum and there are three screws and a cover. Blackcat is right about the mylar! Also when you put the three screws back in make sure they bottom out or the mylar will drag on the drum causing streaks and smears!
            • tmaged
              • 1885
              Do you guys not change the sep pad ? I don't think you can get to it from the process section.
              Hope that helps !
              -Tony
              www.dtios.com
                • 23008
                Originally posted by vincent64
                ... but to change the sep pad for the top tray you have to pull the MFT out, to get to the plate that hides the sep pad unit there...
                Like Vince says, you have to pull the bypass assembly to get to the screw to access the sep pad. While you're there examine the mylar guide that surrounds the sep pad. I've seen a few of these fubar. And it's not much fun to change. =^..^=
                • tmaged
                  • 1885
                  Thanks D, I missed that in his reply. I guess I'll just pull the supplies & extra trays & flip it over. I can get it done in about 10 minutes. Sending you a PM.
                  Hope that helps !
                  -Tony
                  www.dtios.com
                  • vincent64
                    • 382
                    What are you flipping it over for, the mylar or the sep pad, for the pad you dont have to flip it on its side, like the old AR 200 models, and the AR 237-277, thats a big machine to flip solo.
                    • tmaged
                      • 1885
                      By the time you remove the bypass & fight getting those screws out, it's just as to flip it over. You don't have to worry about damaging the mylar & it's easier for the sep pad. Unless there's a finisher on it !! We've put about 30 AR-M257's in our VA and have defaulted tray 2 to the main tray.
                      Hope that helps !
                      -Tony
                      www.dtios.com
                      • Dark Helmet
                        • May 2009
                        • 847
                        The ultimate screw driver for removing the 3 screws under the drum
