Sharp al series
  • Tom
    • 344
    Sharp al series
    Does anyone know what the difference is in the sharp drum cartridge & the xerox version of the same machines. I've got a handful of these al series machines in the field, but I had a customer call in needing a drum replaced in the xerox version. Part # is different, so I'm assuming they're not interchangeable, but why. Is there a trick to make the sharp version work? (they are cheaper than xerox brand)
    • 22993
    My guess? If it's a drum only & blade you should have no problem with interchanging. If it's a unit, it may be keyed differently. The small Sharps do not have CRUM chips on the drum units, so your best bet would be to 'rebuild' old Xerox drum units.
    I've substituted Sharp parts into the small Sharp-made Xeroxes on several occasions. Xerox typically only offers assemblies. If you want sub-assemblies go to the Sharp parts book. =^..^=
    • CCS
      • 266
      Just rebuild the xerox dr unit with a generic Sharp dr and cl-blade for cheap, I have not had any problems with the generic supplies on the AL series machines at all.
      • bilyahn
        • Dec 2006
        • 1470
        The drum units are the same. The difference is in the casing. There is a notch cut out of the back of the Xerox drum unit. You can use the sharp AL drum unit and just notch the casing before you set it in there. Or you can just rebuild as mentioned above.
        Be careful because the drum will fit ALMOST all of the way in the unit without taking the notch out. You will have all kinds of issues then!!
        Good luck.
        Bil
        • CCS
          • 266
          yes, that notch issue got me stumped for a good while one day, unit will go in and run, but just not quite snap in right, then have all kind of issues on and off..., had one in the field running like that for couple of months, simple stuff will get ya...
          • Tom
            • 344
            Thanks for the info, everyone. Looks like they're going to upgrade to a mita 1820 so I'm not going to have to mess with it anyway.
