Sharp SF2030 F codes
  • REHOL
    • Jul 2025
    I have a customer with a Sharp SF2030 copier that intermidently throws F2 codes. I get to the call and someone has turned it off/on again and the code has cleared. The copier then works for a week or so. What are the causes of F2 codes on this model?
  • CCS
    • 266
    You need to adjust the drum mark and image density sensors to get rid of the F2 codes popping up, the values are too far out causing this.
    First clean the 2 sensors in drum unit before re-adjust the values.
    I think the code is 44-2 and 44-3, adjust the vr's on front of the drum unit under cover.
    The vr on the left side will be adj. with 44-3 I believe, and the vr on the right use code 44-2.
    Adjust them both as close as you can get to the value of 204 and you will be good to go...
      • 23008
      Those adjustments are only going to help if your consumables are in good shape. Dead developer, worn drum, or failing developer bearings can also produce F2 codes.
      It would help to know the rest of the code, i.e.: F2-xx
      Hold down the start key with the code present to see the sub-code. =^..^=
      • JustManuals
        • Jan 2006
        • 9838
        This Service manual can now be purchased for $11.77 and downloaded immediately after payment
        from The Internet's largest collection of manuals
        Paul@justmanuals.com
        • REHOL
          Thanks for your help. I will check this out.
