MXC311 scanner
+ More Options
Posts
  • gwaddle
    • May 2009
    • 782
    MXC311 scanner
    Does anybody have a magical way to get into the scanner to clean the mirrors?
    I know I should be ashamed of myself. Strangely though, I am not.
  • OMD-227
    Hahaha.... I just had a quick look at one. You are right.... its not easy huh! There's abit more to it that I thought. I haven't needed to clean optics yet on these.
    As the whole top cover looks like one complete piece, you're going to need to remove some covers and the top cover will unclip from underneath.
    • OMD-227
      Actually, see Service Manual, page 356, scanner section removal. Ouch.
      • gwaddle
        • May 2009
        • 782
        Thanks Wazza, I was really hoping I was missing something. Oh well.
        • Dark Helmet
          • May 2009
          • 856
          Use a Hammer
          Edit: i just looked to, thats pretty frakin ignorant. Better use a sledge.
          • OMD-227
            Hey Lawrence,
            I'm more likely to use the sledge just with regular servicing, not just cleaning the optics!
            • Nachoman4life
              • Oct 2007
              • 212
              c311,401,b401 scanners
              we've been kicking around the idea of drilling a small hole somewhere in the area of home position just large enough to fit the straw from compressed air can in and blowing off the mirrors, haven't done enough checking if there is a good spot to do this yet, but i am betting it would have to be on the rear frame, since the console is in the way of the front frame..
              Where the heck is my spring hook?
              • gwaddle
                • May 2009
                • 782
                One of our guys here is thinking of the same thing. Then just sealing with tape. The problem is even when you get the carriage unit out there is only so much cleaning you can do anyway, kind of like the ar168. We'll let you know how it works out.
                • graybeard
                  • 76
                  Re: MXC311 scanner
                  We pulled one to clean it......my suggestion for future cleanings......use it as a training exercise.
                  • danceswrabbit
                    • Dec 2013
                    • 65
                    Re: MXC311 scanner
                    I had to clean one of these once , pack your patience.
                      • 23009
                      Re: MXC311 scanner
                      Less than 1 hour with practice. It's annoying, but manageable. It reminds me of the typical HP scanner.
                      Every cover off. The whole scanner has to come off, DF off, flip over to remove screws and split in two. =^..^=
