ar-m450 developer issue
  • DINGO
    • 661
    Hy
    Good night, y need yours help/opinion if possible for:
    Today, like the others times, y change the developer in one ar-m450n,
    and the issue was, y execute the 25-2, and gives me higts number
    like 177 and the error EE-EU?
    -the developer was new.
    -the unit is ok, everey gears works good.
    -the the develper sensor was clean??
    some idea?
    thanks in advance.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Do a search for EE-EU and you'll find some helpful tips and things to look for.
    Try running TC 10 (toner add) and then run 25-1 to see if value lowers; it might have been new but have an old 'shelf life'.
    • OMD-227
      When you reset the dev, did you reset the rotation counter as well in 24-11?
      I'd reset both the dev & rotation counts and run 25-02 again.
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1888
        Especially on those machines, I'd pull out the toner sensor & wipe it off after dumping the developer. You can do it carefully with the new developer in it.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
          • 23009
          EE-EU is an undertone condition. I suspect that your developing drive is not turning. I've seen damaged couplers, and broken mag rollers. Truly, the rear end of the mag roller with the shaft and coupler just twists right off. If you put a drive handle onto the developer drive coupler the coupler turns, but the mag roller doesn't. =^..^=
          • DINGO
            • 661
            re
            Ok
            Thanks for any ideas.
            Y do this:
            - clean again the sensor toner
            -execute 5 times the 10-1
            - and again two times 25-2 CA
            and at moment stay good, y don,t now how many time works good.
            the 25-2 stay now in 125 and dthe copy was good.
            thanks for all ideas, but my doubt was because the developer was new.
            thanks a lot,
            • bilyahn
              • Dec 2006
              • 1470
              This may sound stupid but did you use the AR450ND developer? If you used the AR455ND developer you will get something like this? Did it myself once so that is why I am asking.
              Good luck.
              Bil
              • DINGO
                • 661
