Dual Line fax option on any Sharp MFP's?
  • Toner Boy
    • Aug 2007
    • 357
    I think I know the answer...NO. but if anyone has any info to the contrary please let me know. This has come up in the past a few times and I had to sell 'em a Ricoh. Would rather the Sharp but...
    • 22999
    I don't know of any Sharp MFPs but...
    The FO-DC600 stand-alone fax will take a second fax card (FO-60DL). Technically you can add scanning (FO-NS2) which would give you a 3-in-1 (Copy, Fax, Scan-No Printing).
    If you can still find a FO-6600 it came stock with two fax cards, and they were basically bulletproof.
    All the 25cpm & up Copystar MFPs will take two fax cards.
    • Toner Boy
      • Aug 2007
      • 357
      Although the Sharp faxes are decent this customer needs a large ADF for big outgoing fax jobs and a lot of memory to get jobs into the machine outgoing queue quickly. Copystar/KM machines could be an option though. Also, FYI the FO-DC600 series will function as a printer I believe but you need the FO-NP1 optional board installed. I've tried the network scanning on them and although it works, it is pretty weak in comparison to the MFP scanning. Thanks for the reply.
        • 22999
        This is an either/or situation on the FO-DC600. You can have the network interface or the second fax card, but not both (only one port). And I agree that it won't hold up to heavy use as a scanner or printer.
        Overall I'd probably look to another manufacturer. =^..^=
