ARM205 OPE PWB
  • gwaddle
    • May 2009
    • 782
    ARM205 OPE PWB
    Customer had an ARM205 in a carpeted room, and on a dry day, touched the panel and discharged static. The panel will light up and most of it will work for about 2 minutes when you turn on the machine. The original data section never works. I'm assuming the OPE PWB took the hit and needs replaced, but don't have another one to test it. Do you think I'm thinking right?
    I know I should be ashamed of myself. Strangely though, I am not.
    • 22996
    Most likely the damage will be isolated to the panel. Go for it. =^..^=
    • gwaddle
      • May 2009
      • 782
      Someone asked today what we finally did to fix this problem, so I thought I'd pass along what we found. Ops panel replacement didn't do it so just to try something we replaced the ribbon cable and everything came to life. Don't know how it got fried, but it did.
