AR-M700N cleaning paper?
  • nathansipe
    just another tech
    • Aug 2009
    • 122
    The machine is a used machine that likes to print out a paper with cleaning paper written across it in between my print jobs. I dont see a way to turn it off or anything on the sharp tech site. Im sure this is some easy option to turn off. Ideas?
    Best rule for troubleshooting.
    K I S S Keep It Simple Stupid
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1901
    you could try setting 26-6 to a different country reboot, change it back, then reboot again. This wipes all settings however I don't think that will fix it. My guess is you'll have to call the hotline as there's probably a key sequence that the factory uses that was inadvertantly turned on.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
      • 23010
      That was one of the failed attempts to control the toner chip buildup in the fuser, then sprinkling it all over the prints. After only two years Sharp finally decided to redesign the fuser. This probably just a left over bit of firmware that has not yet been removed. If I remember correctly, there was a sim to turn on the cleaning sheet function, so you should be able to turn it back off. I dug through the bulletins, but couldn't find the specific one.
      • Dark Helmet
        • May 2009
        • 867
        None of my machines ever had that but i'd imagine if the machine was upgraded to the latest firmware it would go away.
        At PM time just make sure you have your self a AR703FU1 fuser (north america supply#) so you get the upgraded frame with the oil roller. If i remember the price on that fuser is like 290 bucks and to rebuild it is like 300. If you put bearings in it's definatly cheaper. Saves a ton of tech time to.
        3 weeks ago i had a ARM550 go 400k in a school on it's PM and the fuser looked pretty good. Didn't want to try 800k though. These guys don't call in until it breaks
        • ZOOTECH
          Senior member of CRS
          • 3378
          If the TC 26-6 didn't take care of it, go to TC 55-3 select 7 and turn off bit 2.
