Ar335 doc feeder
  • gwaddle
    • May 2009
    • 782
    Ar335 doc feeder
    I have a test for some old timers out there. I have an AR335 that the doc feeder will close to within about an inch of being closed and hang there. You can push it down and make copies, but it will not stay down. I've opened everything up and can see nothing catching or holding it. The only thing I can think is something happened in one of the hinges, although I have no idea what, that is causing it to hang up. I'm going to install some serviceable hinges next time I can get there, but just wanted to know if anyone has run into this before.
    I know I should be ashamed of myself. Strangely though, I am not.
  • ZOOTECH
    Senior member of CRS
    • 3381
    Is the rubber spacer on the pwb cover for the doc feeder? (P/N 0CW21566P265// - AR-AF1, AR-RF1 Parts Guide section 1 item 52)
      • 22688
      I'm voting for worn out hinges. The left is usually the worst.
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1812
        Ooohh Blackcat, My vote is MOST definitely with ZOOTECH. It's the rubber stopper on the metal plate on the bottom of the ADF. I just happen to carry one !!!
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
          • 22688
          Is this what you mean (#52)? I've seen plenty of machines that this is totally gone, and it seemed to make no difference.
          • tmaged
            • Oct 2008
            • 1812
            That's the one. The adf won't close all the way without that little booger !!
            Hope that helps !
            -Tony
            www.dtios.com
            • gwaddle
              • May 2009
              • 782
              I don't mean to doubt your wisdom tmaged, but why won't it close. By the way it is missing.
              • tmaged
                • Oct 2008
                • 1812
                That rubber nipple pushes your size sensor plate down. Without it, the size sensor plate catches on the edge of the ADF belt frame.
                Hope that helps !
                -Tony
                www.dtios.com
                • gwaddle
                  • May 2009
                  • 782
                  OK that makes sense. Thanks. I'll go put one back on it.
                  • CCS
                    • 266
                    I've seen several with this adf have that same issue of closing problems, you can glue anything on flapper or cover plate if you dont have a rubber bumper, just something to push the flapper...
                    • gwaddle
                      • May 2009
                      • 782
                      Just to let you know replacing the button on the pwb cover fixed the problem. Thanks for the input.
