Sharp AR-M455U printing
  • J_Lee
    • Oct 2008
    • 111
    I need to make a 455U a printer! I put a NIC card in it and it doesnt recognize it. Im reading the service manual on it but dont see where you can switch over...
  • ZOOTECH
    Senior member of CRS
    • 3375
    You need the AR-P21 option (includes 40GB HDD, NIC, and main/boot flash ROMs). The option comes with an application number that must be submitted to Sharp for a product key.
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1888
      Like Zootech said, the ONLY way is to register the P21 and get a product key. The ports are active on this machine only in firmware update mode.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • J_Lee
        • Oct 2008
        • 111
        Ok don't mean to be a pain but I have only known Sharps as copiers never had to make them printers until now. I can do a firmware upgrade on an HP with my eyes closed but wouldnt know where to begin on a sharp. Do you maybe have a bulletin or something that could teach me how? Also, we have lots of parts machines could I maybe take the HDD and flash ROMS off of one?
        • tmaged
          • Oct 2008
          • 1888
          The firmware update procedures are in the service manual. I've never had to try it luckily, but I'd think you'll have to switch the NIC, controller PWB & main PWB as to keep the product key with that serial number.
          Hope that helps !
          -Tony
          www.dtios.com
          • mtech
            • Mar 2007
            • 307
            The product key is licensed to the main unit's serial number. No matter what you do you will need a valid key that is linked to the serial number. A key from another device will not work. So if you get everything the machine physically needs to print it will be useless without the key. You must purchase the key from Sharp. Furthermore through a dealer! Good luck.
            • J_Lee
              • Oct 2008
              • 111
              Thanks for all your help we got it done!
