ar-150 copy issue
+ More Options
Posts
  • DINGO
    • 661
    ar-150 copy issue
    1. Hy friends
    Today y have a copy issue that can,t fix that was, sometimes the top side not copy (long side)and appers on the lower side, like copy a little upper side and paste in the lower side??
    Y already clean the lsu unit, and optic sistem?
    Somebody have any idea for help me
    thanks in advance
  • gwaddle
    • May 2009
    • 782
    If I'm understanding correctly, you are getting a double image on the page. If this is the case, the first thing I would do is replace the fuser. The image is sticking on the heat roller and then transfering down the page.
    I know I should be ashamed of myself. Strangely though, I am not.
    • DINGO
      • 661
      Hy
      Isn`t a double image, is like : original 1111111111111111 copy:; 333333333333333 cut in upper side and apears down?
      2222222222222222 444444444444444
      3333333333333333 555555555555555
      4444444444444444 111111111111111
      5555555555555555 222222222222222
        • 23009
        59mm of the rear side of the page appears at the opposite side.
        Is it like the attached samples?
        It's the lasImage Shifted 001.jpger unit. And it's a lot of fun to change. Remove the SPF, the scanner, the delivery unit, then the laser unit. Have fun! =^..^=
        • DINGO
          • 661
          ok
          Yes Blackcat4886
          is that, y atachet my exe., and y already clean the laser unit, and poligon motor, and not fix.
          The problem is intermitent, what is your opinion?
          thanks a lot
          • bilyahn
            • Dec 2006
            • 1470
            From that image the next question is it off of the glass or the document feeder. I would try adjusting the settings in sim 50-1 or 10 as it seems you have a registration issue. Also check your feed rollers and clutches (these clutches have a tendency to slip after you have used them for a while due to a LOT of grease when they put them together). They are a pain to get to sometimes but I always clean and regrease the clutch springs on this series.
            Good luck.
            Bil
            • DINGO
              • 661
              re
              Hy
              thanks Bilyahn, but in this copier( ARF-152) the paper wors in A4R mode, and i don,t see who a registry roller issue can do this effect.
              regards
                • 23009
                If it was a registration issue the defect would have been on the leading or trailing edge. bilyahn is right though. Since the defect is on the front or rear edge and less than 10mm you can adjust it out in simulation 50-10. =^..^=
                • DINGO
                  • 661
                    • 23009
                    The registration roller on the Sharp AR-F152 is stationary in the crossfeed direction, unlike the Canon NP-3050 and NP-4050 for example which the registration roller can shift up to 14mm crossfeed.
                    You didn't mention that your problem was intermittent. That brings me back to replacing the laser unit.
                    • DINGO
                      • 661
                      re
                      Ok
                      Thanks Blackat, y think that to, but there no kind to repair them?
                      regards
                        • 23009
                        Perhaps, but board level repair is beyond my skill level. I'm going to say this one last time: Replace the laser unit.
                        • DINGO
                          • 661
                          Hi
                          Blackat, thanks for your help.
                          Definitely the issue was in the laser unit, but i could fix it
                          whithout replace for one new.
                          I disassemble it ,and carefull took off the poligon motor
                          and found cold welding in own boadr that repaired.
                          I to also put a little of oil in the came of poligon motor.
                          And chek to the VR1 contacts and VR1 weld.
                          Finaly all mounted and works good.
                          Y hope this description can be util for someone else.
                          Thanks Blackat, Bill
                          regards
