ar-150 copy issue
  • DINGO
    replied
    Hi
    Blackat, thanks for your help.
    Definitely the issue was in the laser unit, but i could fix it
    whithout replace for one new.
    I disassemble it ,and carefull took off the poligon motor
    and found cold welding in own boadr that repaired.
    I to also put a little of oil in the came of poligon motor.
    And chek to the VR1 contacts and VR1 weld.
    Finaly all mounted and works good.
    Y hope this description can be util for someone else.
    Thanks Blackat, Bill
    regards
    replied
    Perhaps, but board level repair is beyond my skill level. I'm going to say this one last time: Replace the laser unit.
  • DINGO
    replied
    re
    Ok
    Thanks Blackat, y think that to, but there no kind to repair them?
    regards
    replied
    The registration roller on the Sharp AR-F152 is stationary in the crossfeed direction, unlike the Canon NP-3050 and NP-4050 for example which the registration roller can shift up to 14mm crossfeed.
    You didn't mention that your problem was intermittent. That brings me back to replacing the laser unit.
  • DINGO
    replied
    replied
    If it was a registration issue the defect would have been on the leading or trailing edge. bilyahn is right though. Since the defect is on the front or rear edge and less than 10mm you can adjust it out in simulation 50-10. =^..^=
  • DINGO
    replied
    re
    Hy
    thanks Bilyahn, but in this copier( ARF-152) the paper wors in A4R mode, and i don,t see who a registry roller issue can do this effect.
    regards
  • bilyahn
    replied
    From that image the next question is it off of the glass or the document feeder. I would try adjusting the settings in sim 50-1 or 10 as it seems you have a registration issue. Also check your feed rollers and clutches (these clutches have a tendency to slip after you have used them for a while due to a LOT of grease when they put them together). They are a pain to get to sometimes but I always clean and regrease the clutch springs on this series.
    Good luck.
    Bil
  • DINGO
    replied
    ok
    Yes Blackcat4886
    is that, y atachet my exe., and y already clean the laser unit, and poligon motor, and not fix.
    The problem is intermitent, what is your opinion?
    thanks a lot
    replied
    59mm of the rear side of the page appears at the opposite side.
    Is it like the attached samples?
    It's the lasImage Shifted 001.jpger unit. And it's a lot of fun to change. Remove the SPF, the scanner, the delivery unit, then the laser unit. Have fun! =^..^=
  • DINGO
    replied
    Hy
    Isn`t a double image, is like : original 1111111111111111 copy:; 333333333333333 cut in upper side and apears down?
    2222222222222222 444444444444444
    3333333333333333 555555555555555
    4444444444444444 111111111111111
    5555555555555555 222222222222222
  • gwaddle
    replied
    If I'm understanding correctly, you are getting a double image on the page. If this is the case, the first thing I would do is replace the fuser. The image is sticking on the heat roller and then transfering down the page.
  • DINGO
    started a topic ar-150 copy issue
    ar-150 copy issue
    1. Hy friends
    Today y have a copy issue that can,t fix that was, sometimes the top side not copy (long side)and appers on the lower side, like copy a little upper side and paste in the lower side??
    Y already clean the lsu unit, and optic sistem?
    Somebody have any idea for help me
    thanks in advance
