sharp L6-10 intermittently
  • jpcopy
    • Apr 2006
    • 256
    the lasier code comes up and POPO machine and it works again. think the lasier going bad? have ESP surge protectors on machines and one has a line conditioner also with it. service manual says to ck connections but machines have been working for over a yr in locations and no problem. these are ARM 350 and 450
    Thanks for any responce
    • 23008
    Yes sir. I've changed a lot of those lasers. If you're lucky it will be a late production engine. It's a 15 minute job. If you're not so lucky it's an early production engine, which has a very inconvenient frame crosspiece in the way of removing the laser. Then it's a 3+ hour job and the machine is stripped.
    The way you can tell is to remove the right cover from the engine. If here is a flat metal plate with a couple of mylar flaps around the top of the laser that is easily removed with two screws, congratulations. If that metal plate has screws through the front and rear frames, bring a lunch.
    I wrote a procedure the last time I saw one of those early production engines. If you want it, PM. =^..^=
    • jpcopy
      • Apr 2006
      • 256
      we have had lasers go bad but when they throw the code it was all she wrote. any other causes to throw that code that you can think of?
      • Dark Helmet
        • May 2009
        • 850
        I replaced the laser motor in every machine i had in the original tiger series. (ARM350/450) Around the 3 year mark they died, i always had to keep a laser motor in stock. Once the new motor was installed it never had a problem. The laser motor was added as a service item later in production so i have a feeling they changed the motor. The board looked differnt. I have yet to touch a ARM355/455 or MX laser.
        If i remember right you can use the laser motor from a ARM355 in the ARM350, they should be interchangeable.
          • 23008
          No, it's always the laser. I've never done anything else for an L6-10.
          • Dark Helmet
            • May 2009
            • 850
            L6-10 is polygon motor lock. Machine is not detecting that it's spinning up. Only once ive had it where the laser was actully at fault.
            Changing the laser will for sure fix your problem but it's a lot more money vs just replacing the motor.
            • jpcopy
              • Apr 2006
              • 256
              Thanks for the replies
              jp
