Sharp AR-M350 Black Copies On Second Side
  • Buddy
    • Aug 2009
    • 285
    I'm getting black copies on the second side of a duplex. (They look like black dashes.) I checked SIMs 53 and 63. I also changed the doc feeder CIS unit with no luck...Any Ideas? Thanks
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1880
    Check the pins in the connector from the scanner to the print engine. I've seen pins get bent in there cause some weird stuff.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
      • 23006
      The old style SPF wiring harness can create some seriously weird issues only affecting second side images. =^..^=
