sharp ar-m550u
  • Gammer0918
    • Jun 2025
    sharp ar-m550u
    I'm looking for NIC (network interface card).It embeded to ar-p19 priter expansion board.Where can i find it?
  • bilyahn
    • Dec 2006
    • 1470
    Actually it is just 2 ROM's and a NIC card when you upgrade to network print capability. The U version does not come with network print capabilities as a default option, it has to be purchased seperately. If you have it installed it is located on the right rear corner of the coppier. You will see a USB, parallel and serial port with a ethernet port. If you find the other 3 ports and not an ethernet port you do not have the NIC card istalled. You can go into custom settings and look at your network settings or the product key to see if you have this installed or enabled.
    Good luck.
    Bil
    • Gammer0918
      I open rear panel ,iknow it dont have .I want tobuy NIC but i dont know where to purchase it.Thanks
      • bilyahn
        • Dec 2006
        • 1470
        You don't need to open the rear panel. The entire print control board will slide out from the right side of the machine. Look just to the back side of the bypass tray and remove that cover if you need to get into it. If you are trying to purchase the network expansion kit get in touch with a Sharp sales rep since you will need a product key to enable the function. Just adding a NIC card will not allow you to print.
        Bil
