arm-450 paper jams in tray.
+ More Options
Posts
    • 23010
    #16
    Originally posted by DINGO
    hi
    ... the issue was fix, i replace the spring and now was ok....
    my best regards
    rpn1999: I think you missed that this problem is fixed. I usually stop fixing when the symptoms abate.
    • repn1999
      • May 2010
      • 310
      #17
      I'm glad the problem got fixed. I missed that part. And I appriciate your input wazza. And generally you are correct and that is the usual case. But I happen to have a lift motor at the office right now, with a twisted shaft that was caused not from age, but by overfilling the trays over time. And it will the same exact thing this thing was doing because it just lifts enough to barely touch the lift detection sensor. When you start runnng it the shaft doesn't turn as fast as it should during the job, and eventually it tries to pick up the paper that isn't quite lifted and jams.
