ARBC260 scan problems
  • bilyahn
    • Dec 2006
    • 1470
    Having bar graph type images overlaid on my copy and 46-24 print. Have reflashed ROMs and was going through the color calibration with satisfactory results until I did a 46-24 print. Please see attached document. This has been an on-going problem that I initially resolved by properly grounding the unit but it has since returned. Have the unit now in the shop to do with as I like so any and all suggestions are more than welcome. The bar code image only occurs on color copies/prints, B/W are fine with good CQ.
    Thank you for your time and effort in this matter.
    Bil
    • 23008
    What a cool unique image.
    I've never seen anything like that before but,... the only real candidate is the MFP PWB, or possibly the print controller. Since it uses LED exposure there is not a common laser unit for all colors. The "barcode" areas appear to have C, M, Y, & K color components, ruling any one individual LED assembly.
    The fill is not very good. Have you tried changing out a couple of the toner cartridges to improve the fill? The word I got from my Sharp tech rep was that the machine should have (4) new cartridges before doing a calibration. I must confess that I didn't do it very often. =^..^=
    • bilyahn
      • Dec 2006
      • 1470
      I should of given a little more information. All the toners have been replaced although not recently but within the last 200-300 color copies. This machine has a total of 13K copies of which 1600 are full color. I noticed the fill as well but that is the best image that I had. The color copies had smaller "barcode" images in more places. Normally I don't do the toners for a color cal unless it is showing toner is low but in this case I know the toners are full and the mag roller looks good (no lines like these toners like to do). I have another machine to swap stuff with (a ARC260M so only the consumables). I was thinking that I would start at ADJ #1 in the SM and just go step by step and see what happens. I was hoping someone might have seen this though and save me a few hours of work.
        • 23008
        Good luck, and let us know how it goes. =^..^=
        • OMD-227
          I've had this exact issue. It was a few years ago, but I remember it quite well.
          It was the ICU memory. Its under the standard output tray. Take that cover off, then the metal cover. You will see some SD-RAM modules. The problem will be one of those.
          Same issues with the color copy/print too. It also can cause part of the testcart copy to appear in the wrong parts of the page, eg, scrambled data.
          If its not the ICU memory, I'll be very surprised!
          • OMD-227
            Come on Bill, dont keep me waiting............ I am so keen to know if your issue was fixed by the ICU memory.
            As I had only ever seen this problem once before (and was certain I never would again), I am really hoping new ICU memory was the fix. Please advise.
            • bilyahn
              • Dec 2006
              • 1470
              Well I swapped the memory but then I had to head out without doing anything. Crisis management at it's best and I didn't get back to the shop until after close of business so hopefully I'll be able to confirm your advice tomorrow!!!! I surely hope so!
              • bilyahn
                • Dec 2006
                • 1470
                Okay here is what I did. I swapped the memory (ICU first), same problem, added additional memory, same problem, swapped print controller memory, same problem, swapped print controllers, same problem. Put everything back to the original configuration, problem went away?!?!!?!?!?!?!?!?!?! WTFO I figure it will come back in a short period of time and I will get called out for it again. An interesting side to this. I printed out various test patterns. The 61-4 skew and focus patterns were just fine, also the 64-1 pattern 9 (the 4 color bars) and a couple of other test patterns, but the 64-2 image had barcodes on it as well as the 46-24 test pattern. We loaded it back up for it 90 mile trip home and we shall see. All the memory I used was from an operating machine in good condition.
                Thanks for all of the information. I'm sure we will be revisiting this problem in the near future.
                Bil
                • OMD-227
                  Well..... I am surprised!
                  I was sure it would be the ICU memory. But I've only seen that issue once before, and that was the fix..... so who knows.
                  Weird one for sure. Hope it stays working for you.
                  • bilyahn
                    • Dec 2006
                    • 1470
                    Thanks wazza. This one is going to have my boss pulling his hair out for sure!! Luckily we have access to a good supply of spare parts for this series. I figure if it comes back it must have something to do with the ICU board itself. But we can hope that it will stay gone this time. Thanks again for all of the help on this and all of the other posts that you have commented on. Blackcat and you are fantastic with your level of experience and knowledge.
                    Have a wonderful day.
                    Bil
                      • 23008
                      I'm glad to help when I can. Maybe next time... =^..^=
                      • OMD-227
                        No problems Bil, it sure makes life easy when dealing with a great & experienced tech like yourself.
                        With that Whale of yours, I agree that the problem would be the ICU board now. The ICU board is what writes to the LED units. My Whale that had the exact same 'barcode' printouts was the ICU memory, yours must be the ICU board if you're sure the memory was good.
                        Or....... upgrade that sh*tbox to an MX!
                        • bilyahn
                          • Dec 2006
                          • 1470
                          Would love to but the client is a rural agency that stretched to purchase this 5 years ago through state grant money and we want to do right by them. We shall see what happens. The sad part is they are our only customer in this town so we don't get over there very often and can't just drop in!!
