Sharp AL-1655 CS
  • GottaFixEmAll
    • Jun 2007
    • 55
    Sharp AL-1655 CS
    This model has two cassettes ...
    Feed problems from top cassette, works occasionally, then not at all
    Switched to bottom cassette, worked fine at first, then stared not feeding ... then it'll work again, then it quits entirely ...
    Switch to bypass, works ... eventually quits, now it's working again - according to customer: it wouldn't feed at all yesterday ... but it (the bypass) worked in my shop today !!!
    I'm thinking that it's probably a driver chip on the main board, the clutches are good, and if manually fired at the appropriate time, makes a copy and timing and image are fine !!
    any ideas ??? ....................... Thanks, Mike
    • 23008
    What jam codes?
    Without any real information I can make some baldfaced guesses. How about the exit sensor flag? Is it moving smoothly, properly? Is it damaged? Try testing the sensors individually in sim 30-01 to see if any of them are intermittent. =^..^=
    • GottaFixEmAll
      • Jun 2007
      • 55
      Sharp AL 1655CS
      The problem isn't jamming ... the problem is that the feed tires don't turn, no paper is fed !! first the problem was with the top cassette, then the bottom, and now the bypass ..................
      I tried removing and resetting all the connectors on the main board, same problem ... except that this time both cassettes won't feed !!
      If I trip the upper feed solenoid the clutch turns drives the feed wheels, picks up paper, sends it thru the copier and makes a copy !! ... (with careful timing that is)
      I originally thought that a paperfeed sensor in the scanning (or optics) section might be dirty, but wouldn't that cause a jam code ?? possible related to optics movement ???
      I'm still thinking that the main board has a problem ... but I've never had this problem with one of these !! I have a AL-1540 but the board is different so I can't swap it .........
      Thanks, Mike
        • 23008
        It can really only be the main board, by your description anyway. Take the leap... =^..^=
        • GottaFixEmAll
          • Jun 2007
          • 55
          Sharp AL 1655CS
          It is a leap !! ... although 99.9 % sure, being an independent and not having similar machines in stock, you have to pop for a board and hope that fixes it ... I will talk to my Board Repair facility and see what they think - not sure if Ambassador fixes Sharp, but HyTech might !!!
          Thanks for the help !!! Mike
          • djwhoo
            • Aug 2013
            • 117
            Re: Sharp AL-1655 CS
            What jam codes?
            Boy would I love to have any kind of service manual for the sharp al-1655..
            it would save me alot of "google" time if i could actually test out the components.. would it be possible for me to obtain the service manual?
            • djwhoo
              • Aug 2013
              • 117
              Re: Sharp AL 1655CS
              Thanks, Mike
              I am having The EXACT same problem.. tray 2 will not turn at all and says "add paper to tray 2".
              • Toner Boy
                • Aug 2007
                • 366
                way back when the predecessors of these were introduced the 'v' tooth of the solenoid triggered arm that stops/releases the spring clutch would stick in the gear (clutch ring). By lightly melting the tip of the 'v' it would keep it from sticking and would still work fine.
                You should take the back off and see if the solenoid is trying to activate the arm or not for all trays, maybe the spring clutches are just crusty from age.
                • oldrn
                  • 166
                  Is this machine in an environment where the clutches might be dirty? Even if not, a bad clutch can put too much force on the clutch sleeve. When the solenoid tries to pull in, it doesn't have enough force to pull due to the extra resistance. The solenoid might work in simulation because there isn't the added pressure - nothing is turning so the extra resistance isn't there. Also, the damper pads on the solenoid can get sticky with age but that should show up in simulation or intermittent feeding. The solenoid pulls the actuator but then won't let it go due to residue from the old pad.
                  • JustManuals
                    • Jan 2006
                    • 9838
                    paul@justmanuals.com
