ARC-260M double count
+ More Options
Posts
  • hana_freak
    • Oct 2008
    • 44
    Hi there,
    Anyone knows how to enable the double-count when a A3 copy is done.
    Antonio
  • bilyahn
    • Dec 2006
    • 1470
    It should be defaulted to double click but if not then sim 26-5.
    Good luck.
    Bil
    • hana_freak
      • Oct 2008
      • 44
      This will works with Xerox C226?
      • bilyahn
        • Dec 2006
        • 1470
        It says that they are the same machine so I don't see why not, But I have not seen a C226 so can not state that it is so 100%. If you can get into diagnostics the same way as a sharp then the sim codes should be the same. I know that the small workcentre that sharp makes for xerox work this way.
