MX-4501 PPD2_N1 Jam
  • vidarb
    • Mar 2010
    • 25
    MX-4501 PPD2_N1 Jam
    I have a MX-4501 that jams right before the reg.roller. Sensor PPD2_N1.
    Suspecting the reg.roller dont move.
    Anyone had this problem?
    Even a broken clock is right twice a day.
  • bilyahn
    • Dec 2006
    • 1470
    Had a similar problem with a MX5001 and it was due to a cleaning blade flipping on the black drum. It would jam in the same place everytime and give a PPD2 code. Take out the primary transfer belt and look at your drum units to see if any of them are covered in toner.
    Good luck.
    Bil
    • vidarb
      • Mar 2010
      • 25
      Problem solved.
      The motor (RRM Drive motor) that drives the resist roller had come out of position.
      • dave1984
        • Feb 2010
        • 3
        PPD2_N1 jams
        This is a late reply, but for general info: the PPD2 sensor seems to fail a lot more frequently now than in the past; even though the same sensor is used in everything from the old ARM450 up to a Hercules. Often the sensor will test good, but still cause you problems.
        One trick is to activate the sensor for several seconds instead of just doing a momentary test. You will sometimes see the state begin to switch back and forth.
