arm451 ce-00
  • TCS009
    • Nov 2009
    • 21
    arm451 ce-00
    greetings all.
    i recently attended an arm451, the customer was wondering if i could disable the network error ce-00, i know it can be done, i just cant remember how it is done. i believe its a soft switch in sim 55-3 but im not sure what one. thanks
    nick
  • bilyahn
    • Dec 2006
    • 1470
    If it's like all of the rest. It's sim 66-1, soft switch 103, bit 8 from zero to 1
    • spotlifter
      • Mar 2008
      • 65
      Wouldn't it better to go to the custom settings->key operator->00000->network settings->disable it and restart the copier?
      sigpic
        • 23009
        Same effect. =^..^=
        • Peter Sim
          • Sep 2008
          • 445
          Is the same with ar-m450n ?
          Thank you.
          • bilyahn
            • Dec 2006
            • 1470
            Yes it is.
            • ZOOTECH
              Senior member of CRS
              • 3375
              Thank you.
              If softswitch doesn't go to 103, use 80 with bit 8 to a one. On the older models, TC 66-1 didn't go as high as 103, but I'm not sure on this model.
              • Peter Sim
                • Sep 2008
                • 445
                Thank you both of you for the info
