AR-M237 dumping developer
  • soonerfb06
    • Jun 2025
    I have a problem with a 237 dumping DV. I replaced the DV, drum, blade, mc unit, right side door, and tc unit. I did everything that the Sharp hotline said. Still not cleaning drum completely, but it cleans when I manually turn drum myself. DV was dumped in the back, and it could have ruined a board. Would a firmware upgrade work? I'm open to suggestions to what could be causing this problem. It has only 30k copies.
  • dingdong
    • Dec 2007
    • 9
    AR-237 dumping developer
    All you need to do is checking the main charge or the contact spring which is contact to the maincharge
    Note: sometime the spring contact have offline ( not correctly firm seated ) make sure when you open the drum unit out, take a look at those three contact to the main charge , I belive you will solve that problem
    • bilyahn
      • Dec 2006
      • 1470
      Did you replace the drum with a new one or rebuild it? On the charge unit there is a metal flange (hook) near the middle that has to hook into the plastic of the drum unit. If this is not properly positioned it will drag all of the DV out of your machine, the drum will fit into the unit even with the plastic bowed out a little bit. Hope this is helpful.
      Good luck.
      Bil
        • 23002
        Hey, I did that once... =^..^=
        • TechGeek
          • 158
          So sooner were you able to figure out what the problem was? If so let us know.
            • 23002
            I was referring to Bilyan's comment about not getting the primary charge unit hooked in properly at the center. It added an unscheduled 30 minutes to the PM I was doing. Honestly, it's kinda hard to see even when you're looking right at it. =^..^=
