sharp al 2040 cs adf problem!!
  • gerryhuerta
    AccService
    • Jul 2009
    • 198
    i have a sharp al 2040 cs printer that lets me scan and copy just fine using the flat bed. but when i try and scan or copy using the adf, the scanner lamp just stays stuck in the home position trying to get over to the right side where the copies will go through the adf, and makes a wierd noise. i noticed that when its on the flat bed there is a drikve pulley in the back that starts to spin, but dosent on the adf copy mode... any help, i have no clue of where to start, has anyone had this issue? thanks
  • TechGeek
    • 158
    Maybe try a 41-06 with about 40 sheets of plain white paper on the Glass.
    • gerryhuerta
      AccService
      • Jul 2009
      • 198
      whats a 41-06? and how do i do it?
      • TechGeek
        • 158
        I recommend getting a service manual to help with this procedure. It will also help you in the future.
        • repn1999
          • May 2010
          • 310
          also make sure the scanner unit lock is not turned up. even if it copies fine from the glass, if you turn that knob to the locked position it will keep the scanner from getting far enough over to get to scan the things you are trying to feed through the adf
          • gerryhuerta
            AccService
            • Jul 2009
            • 198
            i thought about that also. i took it off and it still keeps doing that, any help with the 41-06 techgeek was talking about? thanks
            • TechGeek
              • 158
              Try this attachment. It may not seem like it is relevant but try it any ways.n n Good luck
              • gerryhuerta
                AccService
                • Jul 2009
                • 198
                the machine that i have is a 2040 cs. it dosent have the display like the one in the manual.
                • TechGeek
                  • 158
                  Even thought the display is different i do believe the the SIM will work the same. Give it a go and let us know.
                  • gerryhuerta
                    AccService
                    • Jul 2009
                    • 198
                    will give it a shot, but how do i get into service mode on this machine??
                    • TechGeek
                      • 158
                      Try "C" "EXPOSURE" "C" "EXPOSURE" within 2 seconds the use the key pad to input your numbers
                      • gerryhuerta
                        AccService
                        • Jul 2009
                        • 198
                        okay so i did the 41-06 in service mode and it flashes a 51 and a 98 on the display. any idea on what that is.?
