Sharp AR-M450
  • timothymader
    • Jun 2025
    [Error Code] Sharp AR-M450
    I have a customer who has been using this machine with no problem. Last week he moved it, was working fine, then today, L6-10 error code, right out of the blue. Anyone have any idea's what wrong and what to do, with out replacing the laser unit.
  • DINGO
    • 661
    re
    I fix that as replace the poligon motor
    regards
      • 22999
      You'll end up changing the laser unit 10 out of 10 times. I would be hoping that it's a new style engine. It's the difference between a 15minute job, and a 3 hour+ job. =^..^=
      • OMD-227
        Sounds like a coincidence to me. The machine being moved has nothing to do with the problem. Listen to the main man Blackcat. Do the LSU. Been there myself. It'll come back and bite ya if not replaced.
        • repn1999
          • May 2010
          • 310
          be sure you get the new type LSU. there was a problem with the polygon motor IC on the LSU control PWB and if you dont get the new type you will be replacing it again for the same problem.
          • jpcopy
            • Apr 2006
            • 256
            also check wall power. be sure to have good filter on it
