L6-10 on Sharp ar-280
  • insideout
    • Aug 2025
    [Error Code] L6-10 on Sharp ar-280
    Hello,
    sorry but my english isn't well. My copier from Sharp ar280 show me this errorcode L6-10 and i found information that it is the "Rotary cassette position sense failure" but i can`t find this part in the partlist of this copier. Please help me to find the exakt description of this errorcode to find the part i have to change.
    thx a lot
  • OMD-227
    L6-10 is an LSU/Polygon motor failure. Run sim 61-01 to confirm if polygon motor has gone bad. Your information is wrong regarding rotary cassette.
    Basically, you're up for a new LSU, or the polygon motor unit if you can find one.
    LSU part number is DUNT-6984FC22
    • insideout
      @ Wazza
      thank you verry much for quick answering
      i run sim 61-01 and get
      Originally posted by AR280
      "LSU TEST NG"
      what does it mean, i don't have any paper to look for it or idea
      and in my partlist i can find only DUNT-6935FC11 i think it mean's the same LSU unit
        • 23010
        wazza is right, or course. The failed test means that you need to replace the laser unit. I would be very surprised if there weren't two dozen posts on this subject. Try searching "L6-10". =^..^=
        • OMD-227
          That part number will also work, its just an old number. That part suits AR280, 285 & 335.
          Basically, order whatever you can get. Its an old series, you might have trouble getting parts easily.
          Good luck mate.
          • DINGO
            • 661
            Hi
            Insideout
            if you are in U.E, near of portugal, and as wazza said, the polygon motor is the same of the ar-285, 335, i knwo who as someones of this motors ( used of corse).
            if you are interessed i can get the information for you.
            by
            • bilyahn
              • Dec 2006
              • 1470
              You can try to take the polygon motor out and spin it by hand. I have done this a couple of times to get them to continue working. Worked a few times, if you can't find the part. Make sure to clean the mirror surfaces.
              Good luck.
              Bil
              • insideout
                • repn1999
                  • May 2010
                  • 310
                  wazza is correct, but id like to add something. You can get the "new" type of LSU from sharp. Its important to get the new type because the motor isnt what goes bad inside the LSU its the contorl IC on the LSU control PWB. The new rev part number is DUNT-6984DS52, and I verified that you can still order it from sharp. Hope this helps.
                  • repn1999
                    • May 2010
                    • 310
                    If you cant get the whole unit just replace the polygon motor and youll be fine. part number for that is RMOTP0910FCZZ.
                    thats what we do because the unit is $390 and the motor is bout $100. never had a new one go out yet.
                    • Dark Helmet
                      • May 2009
                      • 861
                      Same here Repn. We always replaced the LSU motor with the new style and they have never failed since.
                      • DINGO
                        • 661
                        Hi
                        the copier is AR-280, or AR-M280????
                        they are diferents.
                        • repn1999
                          • May 2010
                          • 310
                          idk but my posting was for an arm280. wasnt aware there was a ar280.....ive only seen an ar286
                          • Dark Helmet
                            • May 2009
                            • 861
                            Topic is about a ARM-280 which is the same as ARM350/ARM450 also known as the Tiger series.
                            The entire LSU for the ARM350/450 are differnt part numbers. The Polygon motor is the same. I would assume it's the same # in the ARM280
                            • DINGO
                              • 661
                              Hello,
                              thx a lot
                              Ok
                              Sorry, i was think that you are talking about AR-280.
