AR M445N reset Maintenance count
  • scepter2112
    • May 2009
    • 72
    I am tring to help out a friend. I need to reset maintnance count on AR M445N until kit can be obtained. I haven't touched a sharp since they went Digital.
  • efe311
    • Oct 2008
    • 114
    OPEN THE SIMULAYION BY PRESS ( Copy mode key ON → Program key ON → Asterisk (*) key ON
    → CLEAR key ON → Asterisk (*) key ON → Ready for input ) MAIN CODE 24 SUB CODE 4 THIS WILL RESET UR Maintenance count
    • bilyahn
      • Dec 2006
      • 1470
      Also when you do the maintenance you will need to reset 24-5 for developer, 24-7 for drum (if replaced) and 24-11 sub 1 and 2. Don't forget the 24-11 resets. The old sim 20 and 42 no longer apply for maintenance and DV.
      Good luck.
      Bil
        • 22997
        Is the AR-M445N a valid model number? Could you be referring to an AR-M455N? =^..^=
        • scepter2112
          • May 2009
          • 72
          Thanks for the help Efe and Bilyahn, and yes Blackcat I goofed on model number
