questions AR-M450N/350N and MXM-350/450
  • DINGO
    • 661
    • 23010
    Mechanically they are sisters, but few of the parts are interchangeable. Most of the simulations are the same. Essentially an AR-M455N = MX-M450N, and AR-M355N = MX-M350N. There are some significant differences/improvements in the SPF from the Tiger to the Jupiter. You should have no difficulty making the transition. Just more parts to stock. =^..^=
    • DINGO
      • 661
      re
      thanks Blackcat 4866.
      Mi question was because i beguin have dificult to to found goods aar-m series for iport.
      Do you have the service and parts manual?
      thanks a lot for your kind.
      • OMD-227
        MXM350/450 is just the new Jupiter series. Same drum/dev/toner/KA kit. Heaps better ADF, as Blackcat stated. Virtually the same machine, different covers & operation panel. Behind all that, its almost the same. If you know the Tiger & Jupiter1's OK, you'll pick this up easy.
        I'll send you a few interesting documents now, comparing each machine.
        • DINGO
          • 661
          re
          the only thing that i can say is:
