ARM-451N poor quality on second side
  • vlad_robas
    • Oct 2006
    • 225
    When is printing or copy on second side it doesen't have contrast almost all the time. If is one side only is ok. I think is a paper guiding problem but i can't realy figure out where to start.
  • OMD-227
    Hi Vlad,
    If the problem is happening with both Copy & Print, ONLY on the second side, I'd first look very closly at the condition of the Upper Heat Roller. Although it might look OK, a close inspection usually shows a slightly worn coating. This can definitely cause second side C/Q issues, such as ghosting, banding & faint image. Make sure the fuser temps as set to defaults.
    The same issue on both copy & print rues out any problem with the scanner. Check the Drum unit Flange has not worn, as this will cause a density variation on the rear frame side.
    Is the firmware up to date? Ensure that is done, and when replacing drum/dev, ensure the rotation counters are reset as well in 24-11.
    • vlad_robas
      • Oct 2006
      • 225
      It's a scanner related problem.... somwhere on the RSPF ... i will check it closer tomorow.
        • 23008
        I don't understand vlad. Are prints affected, or not? If it's just copies you may want to check the alignment of the SPF with the slit glass. It is a common mistake to try to adjust out original skew by changing the angle of the SPF. All this does is mis-align the white plate with the slit glass. =^..^=
        • vlad_robas
          • Oct 2006
          • 225
          I did about 100 print's on bouth sided and that was ok and then i did try to copy 10 document's 2-sided and the face that was up isn't having contrast.
          • vlad_
            • Jul 2008
            • 98
            Was a similar problem. It was found that the cover RSPF unevenly pressed to narrow the glass. The floor in the room wood and eventually changed the slope of the copier. Tilt RSPF, completely solved the problem.1.jpg
              • 23008
              I think that you may have adjusted the image squareness of the scanner. That also affects the image focus.
              Congratulations on a successful fix. =^..^=
              • vlad_robas
                • Oct 2006
                • 225
                So the promblem is that the DF isn't scanning the document as well as the lower scanning part so i did the shading corection 63-2-2 and no change. I did tryed to lower or raise the scanner with no effect.
                Then i tryed to adjust the CIS position and specialy to lower it with no major efect, then when i did raise it the copy was very poor.
                Atm i don't have any other ideeas of what should i do next!?
                • bilyahn
                  • Dec 2006
                  • 1470
                  Did you try to adjust the height of the DF with the small allen head screws on the top of the hinges? Normally I get darker edging when I need to adjust this but worth a try. Also when I have had a similar problem with lighter copies on the 2nd side I had to replace the scanner board itself.
                  Good luck.
                  Bil
                  • wtroll
                    • May 2008
                    • 85
                    Hi,
                    first clean the 2nd scanner (CIS) glass, after use sim 46.20 (point 5 - DSPF) to adjust the CIS exposure level.
                    The standard value is 128.
                    This would have to help you.
                    Good luck!
                    • vlad_robas
                      • Oct 2006
                      • 225
                      That was it.
                      The value it had was 187.
                      Thank you.
