ARFX7 ROM updates
  • bilyahn
    • Dec 2006
    • 1470
    ARFX7 ROM updates
    Another excursion into the land of futility and frustration.
    Question: Can you update the ARFX7 ROMs that are version 2.00 thru 2.08 to version 4.01 so that it can be used on the MXM260?
    I have tried to update the ROMs on 2 ARM237's and an MXM260. Since I do not have an .sfu file for the FX7 I am using the serial cable method (I used both a 9pin to 9pin and 25 pin to 9 pin cable) with the unit as the default printer. I have done this with the ARM162-207 series without any problems using a similar procedure. The units fail to update. I am using Maint.exe ver 4.22 when I try to update. The maintenance tree never expands and it always shows that the copier is off. 2 of the units lock up with nothing on the display or the Sharp display, 1 unit starts up normally without entering the download mode.
    I can update the ARM237 and MXM260 using the USB connection without any problems. I am using a laptop running Windows XP Home edition. Any suggestions would be greatly appreciated.
    Thank you for your time and effort in this matter.
    Bil
  • OMD-227
    Sending you the step-by-step procedure for these machines now. It uses the .dat file.
    • bilyahn
      • Dec 2006
      • 1470
      Thanks wazza, got it. The only thing that I can think of that I am doing wrong is that I have the wrong type of cable.
      • ZOOTECH
        Senior member of CRS
        • 3375
        It must be a crossover cable, Bil. I can give you pin to pin connection if you need them.
        • bilyahn
          • Dec 2006
          • 1470
          Yes I would like that very much. Thank you zootech.
          bilyahner@frontier.com
