Black Copies on a ARM237
  • hardcore
    • May 2008
    • 26
    Change Deve and Dv unit and did not take care of the black copies any Ideas
  • albasoul06
    charge corona
    • hardcore
      • May 2008
      • 26
      Do you think it is Arching? The saw tooth right?
      • android790
        • Jul 2010
        • 63
        there is a metal ground tab for the grid on the main charge that can come off. i think it is on the rear. i have had this cause me a bad word or two
        Yes, I am here to fix your machine. No, your machine went out of warranty 18 years ago.
          • 22999
          Like everyone else here, I think it's probably a primary charge loss issue. It's relatively easy to assemble the primary charge grid wrong while cleaning.
          If it were an exposure lamp problem you would get an error code. =^..^=
