Help!
  • longton
    • Jul 2025
    Help!
    I have an error message on my AR-206 copier saying E to me and it won't let me copy anything
  • lky1978
    • Mar 2009
    • 483
    hold the start button and let us know the sub error code
      • 23006
      There's more to it. On machines that have only a two digit display, the display may look like (for example) "E7", then when you press the Start key it displays the sub-code (for example) "04". In this example the code is E7-04.
      Now, what code are you getting? =^..^=
      • JustManuals
        • Jan 2006
        • 9838
        This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
        Paul@justmanuals.com
        • longton
          It said 88 when I held down start.
            • 23006
            You're almost there. So far you've given me "E?-88". We're only missing one digit now.
            I'm going to make a wild guess, that you're code is E1-88. That's an E-sort time-out communication error.
            A simple reset should get it going. Try this: Clear > Interrupt > Clear > Interrupt > 14 > Start.
            • longton
              You guessed right I will try it now
              • longton
                It didn't work. Not ruling out that I probably did it wrong
                • spotlifter
                  • Mar 2008
                  • 65
                  Correction:
                  Clear > Interrupt > Zero > Interrupt > 14 > Start.
                  sigpic
                    • 23006
                    Oops! Sorry. =^..^=
                    • longton
                      Did it, When I pressed the zero it flashed 49 then 400 but the start light still went off and wouldn't work.
                      • deep
                        • Jun 2008
                        • 208
                        You should press Clear Key > Interrupt Key > Zero Key > Interrupt Key quickly. The Copy Quality Display will goes out at this moment.
                        Enter 14 and press Start Key to finish the reset procedure.
                        Kenny
                        • longton
                          Did it, display went off as you said then pressed 14 and start but still nothing also the display is still off.
                          • johnbla
                            • Apr 2005
                            • 94
                            Press the CA button ......... to close the simulation and the machine will re start
                            regards
                            John
                            sigpic
                            " The Game never ends..When your whole World depends..On the Turn of a Friendly Card..."
                            • longton
                              It re started but then the same issue still occurred. I press 1 and start to make a copy but then the start light still goes out and won' do anything.
