Sharp MX350N
  • GottaFixEmAll
    • Jun 2007
    • 55
    Sharp MX350N
    Hi, I have one of these that shows an error code: U2-23, a memory error that can be reset with sim 16, problem is that it doesn't seem to have the same code to get into diagnostics as the older AR-M355/455 which used Program * Clear * !! I've servicing this as a like machine to the AR-M355 ... anyone know the correct Sim Code or Diagnostics code ??
    Thanks, Mike
  • OMD-227
    You have the right code, are you in copy mode to start with?
      • 23006
      LOL! I've done that! =^..^=
      • GottaFixEmAll
        • Jun 2007
        • 55
        Well ... probably !! cuz I could swear it worked last time !! the office this one is in is connected - and I'll bet someone had printed to it ...
        Would the error code cause it to stay in either data or scan ?? ( think thats what the modes are called ) but I will go back and check this one out !!
        Is the MX 350 manual substatially different than the AR-M355 manual ??? - wondering if I should get that one !!
        Thanks, Mike
        • bilyahn
          • Dec 2006
          • 1470
          They are almost identical. Same issues as the 355/455 too.
          • GottaFixEmAll
            • Jun 2007
            • 55
            Sounds like the car companies, change a bit of trim, offer a new choice of colors and it's a new model !!
