Sharp 6200 color registration
  • Toefur
    Service Director
    • May 2009
    • 28
    Been having an issue with registration on 2 different 6200's. I bring them into spec using the adjustments in sim 50 and after the machine calibrates itself they are off again. I tried the auto registration sim and after it completes its still way off....am I missing something?? Ive followed the service manual to a tee with no results. Ive also searched the IDNC service site and found nothing. Any help is appreciated.
  • bilyahn
    • Dec 2006
    • 1470
    What are your count totals??
    • Nachoman4life
      • Oct 2007
      • 212
      I'd check the drive gear on the primary transfer unit, cracked/damaged gears will do this (its the gear in the y1 kit)
      Where the heck is my spring hook?
      • OMD-227
        Totally agree with Nachoman. The drive gear on the Primary Transfer Belt Unit can become cracked, causing this exact symptom. I actually had one yesterday, I knew what to look for, straight away found cracked gear. be careful not to loose the pin through the drive shaft.
        Also a torn transfer belt surface can do this. If the belt has been reset or is quite old with high rotations, the edge of the belt can develop a small crack which catches on the cleaning blade, slowing the belt rotation by a split second.
        • Toefur
          Service Director
          • May 2009
          • 28
          It was indeed a broken drive gear on the primary transfer belt. I had two go in one week. Thanks guys!
